2nd Gen Non-Engine/Transmission Gen 2 Rads
Engine/Transmission (1998.5 - 2002) more head gasket question
2nd Gen Non-Engine/Transmission Sagging Insulation
RSchwarzli
How many different rads were used from 94-02 on the Cummins trucks?
I know auto vs standard but past that? Was talking to my dealer to get pricing and see what they are worth and as I don't have a VIN to use, he was looking through the options and there was many.
Can someone educate me? And maybe even provide a PN for a 5600 equipped truck version?
Thanks!
Robert
I just used a 1998 and there is only one choice... ..... Standard or Auto makes no difference as the transmission cooler for an Auto is in front of the rad.
Go into this and play around a bit. If you need help with navigation let me know.
https://www.turbodieselregister.com/forums/showthread.php?232223-Links-to-Dodge-Parts-Fiche-PDF
What Mwilson said. I had the radiator out in the 99 w/ 47re and in the 01 w/ nv5600 and they are exactly the same. Only difference is the 99 had the trans cooler.
Slick! Thanks guys! This is awesome! :)
So wonder what the difference is then between the 98 and 02 is then. Logic dictates newer is better as something was likely improved..... :D
I did not try it, but the part number for the '98 may supercede to the part number for the '02 when all is said and done.
