Geno's 2nd Gen Plastic Dash Cover-Super Nice!
Zie Bart
take a good look at the rear outside corner of your fuel tank
Wiredawg
Fellow Rammers,
The dash on my '02 finally got one of those bad cracks in the dash and was growing bad. This is a chronic problem Dodge has. Anyway, to replace w/ OEM requires dropping the dash, but Genos has this great plastic dash cover product that fits great, looks good and is easy to install. I would have thought it would have warped or would have some imperfections, but all was great. It is packed so well and made so well, I still can't believe how well it worked.
This is good and you should consider over difficult OEM replacement or putting on one of those ugly dash "rugs. "
Y'all take care and Happy Trails!
Wiredawg
i installed one on my busted up dash and love it. one thing that i think i might would have done different is rather then using the silicone that came with it i would sand and clean the old dash and the bottom of the new dash and use 3m double sided tape that stuff that lund uses to hold bug shields on. i dont think it would let go. the smell of the silicone was strong in a hot closed up truck cab after work...
Using double sided tape could work, but wouldn't let you move around to adjust. Despite my wife helped position it, we still needed to move it around slightly to make minor alignment adjustments. I didn't dirive the truck for over a day and had it in my shop where I could keep it open to air out.
Wiredawg
