Is there an isolator? If so, what type is it.
The most common problem with incorrect fuel pressures come from the gauge install or a leak on the gauge side of the isolator. You can remove the fitting on the gauge side of the isolator and use a blunt object like an eraser head to push the diaphragm back to the engine side. This will most likely cure all your issues.
Dave
