Just wondering if anyone can help with some questions. Presently my lift pump is 12 pounds at idle , but will draw down to 9 pounds at cruise and at wot down to 6 pounds. This is the original lift pump with 57,000 miles on it.
I have a new lift pump on the bench and wondering if I could leave the original one in place and mount the new pump back by the tank. This would I think aide the original pump. As to wiring, will tapping the feed wire to the original pump be enough amperage to power the new pump also or would it be best to tap the original wire to run a relay and then fire the new pump with 12 volts directly from the battery? What kind of pressure would I expect?
Or... . would it be best to just relocate the pump with the Geno kit and run only one pump? (the new one)
Or... . just replace the original pump with the new pump in the stock position and again only one pump?
Thanks for any help,
Jay
Jay
