Genos SS eyebrow fender trim
New high Flow Airbox
100# boost gauge
Has anyone installed these? They look like they will hold water behind them and cause rust. I would appreciate any input here.
Thanks, Larry.
Y2K 3500 QC,SLT,4X2,White, 6spd,3. 54 lsd,Banks Stinger +,Pacbrake,Pilar mt. EGT & Boost,Amsoil air filter,all amsoil lube w/BMK-15 filter system,MagTec rear cover,putco boss rbs. w/ rear ext. &flaps,20K reese,100 gal. aux. fuel,fold up T cover,5K airlift bags w/comp. ,ranger 2950 cb pushing palomar 225 amp,phantom radar det.
Hi Larry. I have the full ss trim on and if i could go back i would not have done so. There are several reasons for this, one of which is the problem with water and rust which you mention, even though they have a covering over the lip which fits somewhat tightly. In the part of the country in which i live, water is a constant fact of life, and i have tried to compensate for this by sealing with silicone. i hope for success. there are other reasons: i had to cut/trim my mopar flaps on all wheels;the screws they send are dinky and not up to the task IMO;the screw holes do not wind up where they would cause the least damage to sheet metal (if i take mine off i would need some body work) but maybe i was not as careful as i should have been. anyhoo,they are the only things on my truck with which i am seriously unhappy. i don't know anything about just the eyebrow ones. Walt
99*2500*24VISB*QC*LaramieSLT*4x2*AT*3. 54LSD*All opts xcept cab lights* VDO Pyro, boost, trans and diff temp gauges on dash*BDEbrake*Autolock,midslipTC,VB,PressureLoc,VA*Mag-hytec trans pan and diff cover*Cobra all-in-your-hand cb*Firestick* Speedline sprayed in liner*Better-built low profile bedbox*Rearwheel-well liners*Mopar flaps front and rear*Halogen bu lights*SS wheelwell garnish,"RAM"hmtl,Cumminsbadges*Tailgate light bar*Etc,etc.
[This message has been edited by waboyle (edited 07-23-2000). ]
Thanks Walt. I have a set of the eyebrows, but think I will send them back. I didn't get the full trim because I have front and rear flaps that came with my rb's. I thought about filling the inside void up with silicone, but don't think its worth the trouble. Thanks again.
Larry.
I got a set of the eyebrows. Thet do look good and I havn't had a problem yet. As far a rust, I worry more about my 6speed transmission. It appears to be iron instead of aluminum!
2000, 3500 Driftwood, 4X4, Quad Cab, SLT+ Laramie, Tan Leather, 6 Speed, 3. 54LSD, Tow Package, Camper Package, All Possible Options, Rancho RS 9000 Shocks, Linex Bed Liner, K&N Air Filter, Husky Floor Mats, Geno's Smoothie, Chrome "Down and Out" Exhaust, Stainless Steel Fender Trim Kit, Geno's Charcoal Air Filter, Mopar Bug Deflector, Whisler Radar Detector, AirLift 5000 Air Bags, Smittybuilt Polished Stainless Steel Nerf Bars, Sylvania Cool Blue Headlights, Pro Flaps, 1999 Lance Fiberglas 1010 Legend, TV, VCR, Air, generator, max'ed out all possible options, sleeps 5. Ya Baby!:D:D:D
I have the full SS trim pieces and I wish I could send them back. They didn't fit right at all, IMO, and little dents showed up in them when I tried to push them on. The screws where so small they didn't look like they would hold anything. They were useless. I used rivets instead.
I took them off after only three days and now I have to try to fill those holes they left. If anyone wants a real deal on a set of the full fender ones, let me know!!
Sparky
1999 2500 SLT, QC, LB, 4x4, White, 4. 10 gears/Limited slip, Trailer/Suspension Package, Most Accessaries, Auto transmission, Westin SS Nerf Bars, Painless Wiring, Silencer Ring Missing, Mag-Hytec Diff. cover and more coming (I Hope)!!!
Next addition, Gauges... ...
Pull a 30', Tahoe 5th Wheel (8000 lbs. ) and hardly know it's back there!!
Kind of surpised by the above comments. I put the SS trim kit on some time ago. It was easy to install, and looks good. No problems whatsoever with fit. Although I am satisfied with it, not sure if I'd pay $75 for it again, but it's too late now. Water, what's that? #ad
'99 3500 QC 4x2, AT, 4. 10 LSD, camping/towing pkg. , Mag-Hytec rear cover & trans. pan, Auto Meter gages, K&N air filter, Mopar bed liner & mud flaps, Prime-Loc fuel filter relocation kit, Tekonsha Sentinel brake controller, Rancho step rails; Air Lift SD air springs
Not sure
Anyone else have experience with the Geno's eyebrow trim? Installed photos, problems experienced after being installed for a while? Ordered a set, now not sure if I want to install them. Did a test fit on one and it doesn't seem quite right (I did try it on the proper wheel opening). TIA
David
David, I installed the eyebrows on my '97 and '00 3500, the fronts fit good but the rears require shimming and tweeking. I believe they fit the SWR good but the DRW opening is a tad bigger. I got them to fit pretty good. I put them on because of rock chips on the edge of fender (lip),it covered them and eliminated any more. But I run on some narly gravel in Montana.
I have got photos of the "00 but cant get them to down load. Good luck to you, Terry
Thanks Terry. I appreciate the information. We have a regional TDR evern this Saturday, so I'm hoping to find someone there with them installed on their 3500. I'll then be able to see up close and personal how well they fit.
My best,
David
i have them on my drw. there are some photos on readers rigs of mine. i did have to bend them a little but got them to fit good. i like em. i allways aim the house behind them and the water comes out the front when i wash the truck.
ed
David,
and what i mean by bending is to make the bend on the pice a little tighter so when you push them on they go tight up against the truck. :) just so you know
ed
