Looks like the oil change in the transmission didn't do anything for the first gear problem. . :-( I'm going to have to pull this thing down and go thru it. Has anyone here had any dealings with Standard Transmission and Gear? I'm going to have to buy parts somewhere and was wondering if anyone has had any problems with them or their stuff? You can reply to this Email address instead of posting here if you like. Racer_Brown@hotmail.com
Also, I'll look at the clutch while I have the transmission out so what is the best clutch setup, both price and quality wise, to use in this truck? This thing is getting to be more expensive than the race car!
And finally, I found a shop that has the front end alignment shims to correct the camber problem that I have. They are going to check it to see how far it's off and then I'll buy the shims from them and install them myself. Hopefully that will take care of that problem. See Ya!... ... ... Ken
Ken-1993 W350, Cummins TD, 5 Speed, 4X4, Club Cab, LE, K&N, Straight Pipe.
http://users. lynchburg.net/ken0069
