lubrication
I haven't had a fire baptism in a day or two. So I will see if I can get this thread in high gear. I have a 93 with the getrag. The only problem the getrag has ever had was caused by me and so I don't hold any ill will toward the getrag. When I had the transmission out the first time at about 125k, I felt that the lubrication was inadequate. I (and I alone) decided that it needed a heavier film strength lube. When I reinstalled the transmission, I filled it with aw 85 gear lube. I noticed that the transmission needs a minute or two to warm up before it shifted as normal with the motor oil.
But I have subsequently run the truck another 375+k miles. I have had the transmission out once when replacing the throwout brg and reshimmed at that time. It now needs the third gear syncro and will have to be out some time soon. I looked into the side cover and the gears are mirror bright and all else is well in the transmission. My truck is twd and I have no power upgrades and may not be producing even the advertised stock HP. The Cummins, the truck, 85aw and the getrag have done me a completely satisfactory job. Now you can take that for what it is worth. Two cents?
OK. I'm suited up. Bring on the flame throwers.
1stgen4evr
James
