I had my truck on a nice 4 post lift with the smaller inner scissor lifts Saturday. We were able to support and isolate the front axle for disassembly. I was ready to tear the front end down completely and replace whatever I needed. Right off the bat, we noticed that I had FOUR bad ball joints. I called every parts house in town and two dealers. No ball joints to be found.
. A tdr member/friend suggested that I order the new ones from Quad4x4.com. I will do that, but am also wondering what else I should replace while I'm at it?
Another member/friend suggested that I should go ahead with wheel bearings because of the severe Death Wobble I've had. He said they probably had flat spots. I'm sure he's right. But what else should I look at replacing? U-Joints? What else?
That was a SLICK 4-post rack by the way. I could raise the entire truck up to working height, then use the two center mounted scissor lifts to independantly support the axle and the frame. It was a HUNTER something 'er other. He uses it with a Huter DSP alignment machine. Too bad I couldn't find parts while I had it up in the air.
TIA,
Andy
TIA,
Andy
