Ghost in Speedo/odometer?
Mileage and Higher RPM power
47rh
I was on the road on a 4 hour trip this saturday, and about 5 am while on the highway all of a sudden my speedometer went from 75mph-to zero,and the Odometer ALSO STOPPED working!... yes, cruise control also went south. I made it to my destination,and went out again, was driving like 55mph and all of a sudden everything started working again... :confused: I musta lost about 150 miles on my Odometer, but no big deal really to me, just baffled on why it did this? anybody else have this problem??:confused:
Try checking the distance/speed senser. Might have a loose conection or just plain wore out. It controls the speedometer and cruise control, It's located on the tail, drivers side.
They are a 60. 00 at the dealership.
Jim
Greg,
I remember some of the guys having a problem like this and it was moisture or dirt in the plug at the speed sensor. take it apart, clean it real good and put it back together. If I were doing it, I think I'd try a little dielectric grease on the contacts.
speed sensor
ok. . so where exactly is the speed sensor again?where in the tail is it? and i wonder why,still that it would just come back on after hours of driving :confused: :confused:
Cummnzpwr,
I've got a small nick in one of my wires that causes my speedo to stop or just jump around while I'm driving. Sometimes it will come back in a few minutes or not until the next time at the wheel. It just hasn't been a priority for me yet. Just installed my new 3" exhaust from Jannetty Racing and love to hear the turbo spooling.
Dan
Hey Gregg, I had this exact problem with mine. It started out happening about once very other month or so. Yopu would be driving down the road, and wham 100 -0-100 and back to normal speed. The rate of incidence increased very rapidly to the point of the speedo not working. I cleaned all connections, speed sensors and what not. This resulted in my speedo working but not my odometer. I found this out because my milage dropped from steady 18. 5 to steady 15 mpg. After changing all fluids and checking EVERYTHING I could think of I filled up and drove approx. 20 miles and registered no miles.
Moral of story was I ordered a Instrument cluster from a wrecking yard for 35. 00 and installed the Head unit ( this is what they called the milage cluster thingy :rolleyes: ). Viola, milage was back to 18. 5 steady.
P. S. Only thing that has not worked correctly since installing new head unit was the cruise. It also went south when the speedo problem first showed up. Hope this helps.
