Glendale Titanium 5th Wheel 28E33SA
Planning a RV Trip to Alberta, Ca
D
Advice for picking a auto transport
Anyone out there have a Glendale Titanium 5th wheel? Any thoughts or concerns. I looked of their forum and see that some have had structural issues. Anyone have first hand experience? TIA
I've had my Titanium 25E30 for a year and no structural issues. Checked the pin deflection the last time I hooked up and it was less than 1/2". So far, I've towed it about 4000 miles.
Be sure to check on the non zero offset wheels / Dexter 42mm NevrLube Axle issue.
You will find that many more people on forums complain than praise. Just the nature of things.
You should check with Dexter Axle. Some came with the wrong axle lenght/wheel offset, which caused bearing issues. You might ask about that on rv.net also. SNOKING
I had a Titanium 25E30DS 2005 for almost 10 years with no structural problems. I did however had the axles changed over to ones with Dexter EZlube bearings. When it was built, they did not use zero offset wheels. I already had quite a few miles on the original bearings when I learned about the potential problem,
so I decided to keep the wheels, and go with new axles.
