After spending mucho $$$ on attempts to get my 94 454 Itasca to get off the porch & run with the big dogs I found what others here have found... . I needed a:
intake that breaths (K&N or similar)
quality headers (Edelbrock on mine) with free flow exhaust
top quality distributor... no discount heartbreakers
vacuum lines changed almost every year... it gets hot under the dog house
efficient torque converter & deep pan
I decided I didn't want to invest any additional $$ on a rig that doesn't log that many miles per year. I still only get 8 mph pulling my horse trailer but pull it does. I'm now planning on selling the MH and putting a simple shell on my Dodge. A bed roll, Coleman, and an ice chest works fine for me. The wife wanted the MH.
"I decided I didn't want to invest any additional $$ on a rig that doesn't log that many miles per year. "
YUP - my situation exactly! This is pretty much a local use vehicle - and it would take a long time to recover even the cost of a good exhaust system in MPG savings - that's why so far, I'm focusing upon the cheaper/easier "fixes" to see what can be accomplished.
Another reason I'm hesitant on a full-bore performance exhaust is, there's no place within nearly 300 miles round trip from here equipped for the job on a MH - and added to that, is the smog pump setup and the related plumbing into the exhaust system. I doubt an aftermarket "performance" setup woul provide for that - and if I then needed to remove ALL the emissions stuff, that's quite a job, and leaves me pretty vulnerable if this county ever decided to require smog checks for stuff like this MH...
Our '88 already has the K&N, along with a "cool air" intake duct to feed it. The timing light I ordered arrived, timing had been set to 4 degrees BTDC static, and I moved it to a nudge over 10 BTDC - no signs of pinging, little more vacuum, and pulled the hills better on the fishing trip we returned from this afternoon, CAREFULLY checked the MPG - FULLY topped off the tank before and after the trip - 110 miles round trip, about 40 of those are steep 45 MPH winding road, so lots of 2nd range used - but did pull longer steep straights in 3rd range (no O/D in this transmission), as long as I could keep speed up to 55 MPH or so to keep engine in it's power band.
Bottom line - exactly 7 MPG. Not great by any means - but better than the previous 5 MPG I thought I was getting - but much of that was failure to properly fill the tank to the fill neck - this thing's worse to completely fill than our trucks, and will take another 10 Gallons AFTER you THINK it's full...
I'd sure love to try this thing out in the flatlands - but that may take a while, and this fishing trip is pretty typical of most of the type terrain we will usually travel. Then too - the old '76 Winnebago 22 footer we had with the Dodge 440, didn't seem to make ANY difference whether the road was flat OR steep - it got 5 MPG, and that was IT!
Not sure exactly where to go next with this - might be a little more timing advance left - but better be careful - and it seems the kick-down is not operating, if I mash the throttle at lower speeds - 30-40 MPH or so - the transmission stays in direct range, unless I manually shift down. No mechanical linkage I can see, so the kick down function must be totally controlled by the engine vacuum/modulator?
(EDIT) I find that the TH400 kick down function is electrically operated, probably off the throttle linkage near the accelerator pedal - will check tomorrow...
