I have a 1991 GMC 3500 Crew Cab 1-ton I am doing a conversion on. It has the older cab, 87 back chevy and had a 454 with 4 speed. I already put a 12 valve and a 5 speed transmission in it and have it mounted out of a 1993 dodge 1-ton. I have a few questions hopefully some of you guys can help me with.
#1
How do I need to go about hooking up the p/s and brakes on it. On the 454, the brakes and p/s ran off the p/s pump. I still have the dodge p/s pump on the engine. Do I just need to adapt the lines to the dodge pump?
#2
My next question is on the clutch. How would I go about hooking it up. Do I use the gm slave or the doge slave. Im clueless on this one.
#3
On hooking up the speedometer. My 4 speed had a sensor on the back of the transmission for the speedometer, and so does the dodge 5 speed. What do I need to do to have a wrking speedometer?
#4
On the gas tanks. My tanks had the electric fuel pumps in the tanks. Could I just switch the tops of the tanks t the old style without the fuel pumps in them and use the tanks I have on the truck, of course makeing sure all the gas is cleaned out 1st.
That is all the questions I have for now and any help will be greatly appreciated. I sure cant wait to get this thing going so I can drive it. Im sure I will have more questions down the road.
#1
#2
#3
#4
