Godzilla gets BOMBed at Brandons
a/c panel controls, hows that again?
Shuting off when warm outside?
Hi Tom, glad everything is going great with your truck. I can definately tell Godzilla's making some REAL power now after the ride you gave me. Amazing how hard Godzilla pulled from 5th gear just loafing in the city. I'm jealous now heh heh. Have fun.
Ray
2001. 5 2500,SLT,White Reg. cab,2wd,Auto,4. 10 limited slip,trailertow package,camper package,and ready to bomb. Let the bombing begin.
Ray,
After driving your truck, it seems you are also well on your way... . Sure like to see that BIG Cummins slammed to the ground with some 20's on it... ..... #ad
: #ad
: #ad
Love that turbo sound... .
Colin
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
Tom, I'm quite pleased your enjoying your newly buffed Ram #ad
You have some excellent components on your truck at the moment.
To quote you:
"So, to all those considering injector upgrades, my advice: Don't diddle with piecemeal upgrades, just save up until you can go all the way the first time! DD Stage 3's the first time!!"
I think your right on with that comment. Now that may not fit all applications but for those looking for performance and don't mind replacing the clutch... .....
Tom, Performance Diesel in conjunction with Brandon's "Express Lube & Detail" proudly award you with the "Bomber Of The Show" award (Willyslover gets a close second) You have bravely waved the red flag in the face of that teensy weensy lil' Cummins motor #ad
Well done lad! #ad
---------------------------------------------Nowel/Performance Diesel
Hey Tom... . Congratulations on your new bombs. Joe
White 2001. 5 2500 ST, SWB, 4X4,QC, AUTO, 4. 10's, LSD, 285/75/16 On Weld Outbacks, PIAA 510's, Line-x, Tinted glass, Redline 85+, Blow-by-bye, RE-0880 & 25-0880,muffler fell off,level truck with 2" tuff country kit, Bilsteins at the corners, Di Pricol egt and boost, Mag-hytec "original flavor" transmission pan and Dana 70 diff. cover. Custom Plate 24V-DSL
Colin,
Thanks sooo much for letting me test drive your truck. That tc, vb on your transmission is sweet. Love how fast & firm it shifts when you step on it. Now I REALLY can't wait to get mine done. In time my friend I will get some rims & tires on Torqus Maximus(my trucks name) and maybe lower it. Now I have to find a good excuse for my wife. #ad
Ray
Howdy all,
Just thought I'd share the great news about all the BOMBing I did at the Crntral CA meet at Brandon's shop in Modesto yesterday.
Godzilla got the following BOMBs:
4" Jardine exhaust
DD Stage 3 injectors
boost module
Brandon's fuel line upgrades
full Psychotty air system
Amsoil in both differentials
Sometime later this year: new clutch, HX40, hot "box" of some sort.
Now, for some of my initial impressions.
4" Jardine exhaust: There definitely is a drone in the cab, but in my truck, it seems to be fairly constant from idle up through 2600 RPM. Nice low rumble. But that's why they make stereos, to drown out that sort of noise.
Psychotty: I had the K&N RE-0880 for the last 3 months and no silencer ting. The K&N by itself definitely allows the turbo spool up whistle to be plainly heard, but usually only when boost is building up, or is fairly high. Now, with the full Psychotty, there seems to be whistle even while at idle at a stop light. Again, crank that stereo if you don't like it.
DD Stage 3 afterburners: #ad
Not much else to say here. Man, when you light the afterburner (push the go FASTER pedal), oh boy, does it ever respond!!! Of course since I still have the stock ETH clutch, and the HX35, I haven't pushed the pedal all the way to WOT, as I don't want any EGT problems. Last night coming home from Brandon's shop (about 120 miles), I practically had to keep one foot on the brakes, as Godzilla just wanted to FLY on the way home. All I have to do is think about hauling butt, and he hits 90 in nothing flat. Somebody's gonna have to hit me with a brick to wipe the smile off my face #ad
[Edit]: As far as smoke goes, I had a few of the other TDR folks follow me around Modesto at night looking for a place to eat, and asked how much smoke I was putting out. I admit I still haven't sent the go faster pedal all the way to the floor, don't want to blow the clutch yet, but so far, it has only smoked once, when doing a 3rd gear start from a rolling stop and getting on it a little. [end Edit]
I would like to specially thank Nowel, Brandon and Chris Sutton [csutton7] for their fantastic help in doing the installations of all these BOMBs!!! Godzilla thanks you all very much, and so do I.
Tom
(I need to update my sig)
Tom Golden
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, black SmittyBilt nerf bars, K&N RE-0880 & pre-filter, no silencer ring, Armacoating bed liner, TDR decal, Jack holiday antenna ball
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
[This message has been edited by TomGolden (edited 04-10-2001). ]
Im pretty sure there was alot of "air" #ad
floating around Brandons on sat with that many cummins boys and all of them telling stories and eating elk( which by the way was exellent I had it last night thanks Chris)IM sure there was plenty floating around
2001. 5 ETH/DEE 4x4, DRW QC, DD supermental injectors, EZ, HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, fuel lines,mag hytech rear end cover,psycotty air system,relocated blow by bottle,Lucerix power heated mirrors,more to come
My DD2's are now for sale! I should have listened to HVAC. I want DD3's now!
Bob
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Well, I drove to Fresno and back home yesterday, roughly a 400 mile round trip for me. Man, gotta love that new found power!!
Hey, I've thought of a new BOMB. I was going to order the 5" Chrome Monster Tip from Geno's Garage for my new Jardine exhaust, but I got the bright idea to paint the last piece of the exhaust flame red instead! That ought to grab people's attention going down the road!! A Patriot Blue Dodge with a flame red 4" tail pipe sticking out the back end sending clouds of smoke out just before it disappears into hyperspace #ad
Fortunately, due to the bolt together nature of the Jardine system, I can easily remove the last 2 foot section, prime and paint it properly, then reinstall it. Next weekend's BOMBing project!
Tom
