Engine/Transmission (1994 - 1998) gog. springs and idle
2nd Gen Non-Engine/Transmission head light switch fire
2nd Gen Non-Engine/Transmission Help on boat trailer wiring.....
well i got the springs installed, was intense for a while, but a couple brandy waters later and all is well! the only thing is now i idle at 1k in neutral, in gear about 900. i would like to get my idle back to factory which was 900 in neutral and 800 in gear. what do i do. will the bolt on back of pump do the trick??:( wow what a difference!:D next will probably the transmission:rolleyes: ithink i can slip the tc now with the 10 plate slid forward, lots of egts:mad: have to regulate the foot i guess:D tnx denny!
If you can't lower the idle using the idle screw, you might try backing the gov springs off a click. Mine were set a little loose when I installed then and had to increase the idle about 400 RPM's.
