Hey Curt, when I went through the lemon law process of my uncles 98 Dakota it went very well without any hitches, I paid a lemon law lawyer $50 (if you end up needing his number let me know) and he set out and got my uncle a check for his truck minus the mileage. So if the excellent advice does not work with arbitration let me know and then you can go to a lemon law lawyer; as it states in your manual (lemon law booklet) you have the right to continue on if you are not satisfied with the arbitration outcome, the arbitration is considered a goof faith attempt on your part to allow Chrysler to resolve the issue before a lawyer is involved. Good luck bud were here for you if you need us.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake, Power Edge, Edge EZ, Grover Air Horns
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: any other Ram Runner required modifications...
