I am considering installing the 3K GSK for a couple of reasons.
I think it would help me while pulling a load to be able to run the RPMs up to the 2600-2800 level. By doing this, when I shift into the next gear I will be in a better RPM range for pulling (1700-1900), instaed of 1500.
This should help in two ways:
1 Less lugging of the motor
2 Higher transmission line pressures(Help maintain TC Lockup Clutch)
Currently while pulling a grade with a load(Total weight 18K) I have good power, but if I get slowed down and have to go down to 2nd gear, I have a hard time getting back up into third. This is because in 2nd gear I am pulling 40MPH @2400 RPM and am maxed out on RPMs. When I shift up into third I am @ 1500 RPMs which is too low. Right??
1 What are the drawbacks?
2 How long does it take to get it set right? (Smokewise)
3 Is this a safe way to correct my problem?
