I tried this once on a previous vehicle, and it seemed to work OK. Thought I'd run it by the group to see what you all thought.
1-drain fluid from trans (I have a plug installed)
2-put plug back in, and drive vehicle around the block (include back-up move)
3-drain fluid again
4-repeat step 2
5-drain fliud again
6-drop pan
7-replace filter
8-replace pan
9-fill with ATF++++ or AMSOIL Trans fluid
I get a lot more fluid out by doing this, but I just wonder if it is OK to do this (drive with lower fluid level) for a short distance.
3-drain fluid again
4-repeat step 2
5-drain fliud again
6-drop pan
7-replace filter
8-replace pan
