I have a Scan Gauge which plugs into the OBD port. It monitors all engine parameters, oil pressure, ECT, trans temp, boost, I believe 5 egt points, scr state, dpf %, Regen status. There are many many others but those are just off the top of my head.
Unlike the EVIC the scan gauge will read actual ECT in cold weather.
The owners manual clearly states it is not recommended to idle a cold engine any longer than necessary. It clearly spells out allowing oil pressure to come up and drive easy - assuming of course it is safe to do so - clear windows etc.
Seems clear to me.
Again, as the OP is finding out idling to warm up takes time, burns fuel, and is not recommended. Obviously occasional idling is not the topic here, we are discussing routines IE long term. The block heater and a good outdoor timer is your best friend in cold weather. At my current electric rates it costs me approximately 7 cents an hour to run my block heater. How many minutes you suppose it would take to burn 7 cents worth of fuel? I'm guessing it won't get you very far in terms of making heat, certainly not what the same 7 cents worth of electricity will get you. The more important discussion is the other benefits of using the block heater - zero engine wear, less strain on batteries, starter, etc. It is hands down best practice for many reasons.
To the people who think Cummins endorses idling as a means of warm up I encourage you to seek out information directly from them. Even Ram points out the above information in multiple places RE cold engine idling but they are also no doubt balancing best practice with operator comfort - essentially they are not concerned with the longevity of your engine and emissions components once you've cleared their warranty period.
If anyone is interested I will post pictures of Cummins
recommended warm up procedures. This from equipment with scr equipped 6.7/8.3 engines, and engine operator and service manuals printed in a separate book directly from Cummins - not a section in the back of a pickup truck book or a piece of equipment. Every manual I've seen are all very similar - start and run light loaded - do not idle - and no full engine load until 160*F. In the applications with Grove, they go so far as to recommend putting the crane in gear with foot on the brake and lightly rev the engine in short cycles so as not to overheat the TC as a means of warming up.
