Ok got my order from TST and will be doing the install as soon as I get a new gasket from Cummins (the KDP tab fix). I have read a bit on the transmission temp install. TST says to install the probe/sender in the front servo port on the passenger side of the transmission. My transmission is 47RE. Here is my question. I plan on installing a Mag-Hytech transmission pan within the next 6 months. Should I install the probe/sender in the servo port and then move it into the pan later or get the cooler line w/a port installed and do the install there? What would give my the best most accurate readings? I plan on carrying a camper and pulling a ATV trailer over two lane mountainous roads in Alaska. Eventually (3-5yrs) installing a new Torque converter and transmission from ATS.
Thanks
Dawna
edited for transmission info
Thanks
Dawna
