I was at Dyno-mite a couple days ago, and honed my stockers to 26. 5 liters/minute (on air @ 50psi). I picked that number, based on some graphs they had of other people's gains, and it puffs if I get on it at zero boost/ low rpm, but one second later it's clear as air. (with rokktech sensor, exhaust, large paper air filter) This is 03 305hp, and it flowed 20 stock at 46K miles.
Super smooth, and torque went up precisely 32. 5%. (same as the honing ratio of 26. 5/20=1. 325 --- good job guys!) Noise is identical 75 dBA outside, and less vibration, quieter inside at all rpm. No mpg yet. We got some light snow, so I won't be doing any uphill EGT/boost test yet.
I don't like to give a HP gain, because the ECM defuels in 3-4 steps, causing the horsepower at 2500 rpm to be flat all the way to 3100 rpm. But without that defueling, these are technically 100HP injectors at the engine (1. 325 x 305 = 404. 1 hp) Since torque = hp x rpm, its easy to see that torque drops, for the horsepower to stay constant, at least on his inertia dyno. No boost fooler for me, I want to keep the stock turbo/clutch for now.
I have not felt the torque dropping on the street, so I wonder if the dyno inertia wheel accelerates faster than the truck in real world, causing the defueling. It's a 6 speed, so I don't care about revving the engine that high anyway. I can spin the tires in fourth with 315's and 3. 73.
One of my friends went with me and honed a set of aftermarket EDM injectors. Those things claimed to be 25HP injectors, but were anywhere from 23-26 LPM. Very uneven! That puts the smallest at +45 hp and the biggest at +90 HP gain. Now they are all at 27, which should be good for +107hp. My advice, don't go bigger than that for street use.
SO if you buy EDM injectors, let the buyer beware. Buy stock hp, and send them to hone them and balance them, don't trust that they will be built right. No wonder some people have smoking and roughness issues with EDM stuff.
