Got my new chip today and got some dyno numbers for it
My truck is an 03 2500 2WD HO 6-speed. All runs were done in 5th.
My only bombs other that the box are a custom intake/filter setup (about the same as the AFE kit but cheaper) and 5" exhaust.
the 001. drf run is with the box set to 0x0. 002. drf is setting 1x1 and so on up to 008. drf which is 7x7. on run . 007. drf (setting 6x6) the clutch began to slip so the numbers don't go up much more on torque. Run 008. drf is on setting 7x7 which the clutch was acting up real bad... didn't do any runs higher than that.
Highest EGT I saw on the dyno was 1400 pre turbo on setting 7x7. On the street it will almost hit 1350 on 5x5 from stop to 100mph.
Settings 4x4 and above smoke with settings 6 & 7 completely blacking out what ever is behind you
I left the stock boost elbow in since I can hit 37psi on setting 6x6 with it... no need for the TST one unless you want to run the risk of the turbo blowing up IMHO.
No codes, no knocking and no problems. I did notice the power dip in the 2100 rpms area tough. Build number on my box is 1383.
Heres the break down on the runs:
setting-numbers--------gain-----------gain above stock
0x0 = 272hp 491tq
1x1 = 293hp 546tq +21hp +55tq
2x2 = 304hp 609tq +11hp +63tq +32hp +118tq
3x3 = 325hp 648tq +21hp +39tq +53hp +157tq
4x4 = 365hp 699tq +40hp +51tq +93hp +208tq
5x5 = 406hp 750tq +41hp +51tq +134hp +259tq
6x6 = 437hp 789tq +31hp +39tq +165hp +298tq
7x7 = 451hp 778tq +14hp ------ +179hp ------- (bad slipping clutch)
0x0 = 272hp 491tq
