Got Smarty Jr on the dyno.
6.7 Injectors in the 5.9???
My new Goerand transmission and Browns Diesel
I made 1 run with my 05 auto transmission with the smarty JR on 100 hp performance setting and it rolled out 407 hp and 732 ft lbs tq uncorrected over the weekend Nothing but whats in my sig. From what I see stock 3rd gens run around 270-280 hp and 500tq so the smarty Jr is definately no slouch. I figure along with the intake mod and no muffler it gaied me 130 hp and 200ft lbs tq over what stock rigs I see dyno.
O Yeah I forgot to say I run Schaeffers soy shield fuel conditioner in the recommended dosage.
Thats nice to see I've been wanting to get mine on a dyno but there haven't been any events in my area. so if your at a little over 400 on just the JR in theory I should be close to 500 with the mp-8 stacked :)
stacks great. The new software is almost out.
The items are :
Speed-limiter
RPM Limiter***
Shift limiter***
Torque Management levels
Injection timing
Rail Pressure
Wastegate
The levels are :
Speed-limiter
From 25 to 250 mph in one mile increments
RPM Limiter***
# 0 - Stock
# 1 - 4000 RPM
Shift Limiter***
# 0 - Stock (On)
# 1 - Off ( also shift light indicator will be turned off )
Torque Management
# 0 - Default
# 1 - Stock
# 2 - Mild
# 3 - Moderate
# 4 - Wild ( aftermarket clutch / AT Transmission recommended )
Injection Timing
# 0 - Default
# 1 - Stock
# 2 - for stock injectors
# 3 - for aftermarket Injectors ( less advanced than # 2 )
# 4 - for fuel economy ( more timing advance than level # 2 )
Rail pressure
# 0 - Default
# 1 - Stock
# 2 - Mild
# 3 - Moderate
# 4 - Wild (aftermarket injectors recommended)
Wastegate ( for 2004. 5 and up trucks only )
# 0 - Stock (On)
# 1 - Off ( for aftermarket turbo )
The above descriptions are for the REVO standard software.
How does it work?
If you prefer the Smarty standard software configuration, simply skip the “Adjust Options” menu and
choose the CaTCHER level you prefer, as in previous Smarty software.
If you want to change the default setting of any (or all…) of the customizable items, you can enter the
“Adjust Options” menu, navigate with the “ > “ and “ < “ keys to the item you want to customize and
enter your choice. Done! Smarty will do the rest.
At the end of the items list, Smarty will store your selections in its memory. In this way, your preferred
selections will be applied every time you program your truck.
As a simple example, if you set the Speed-limiter to “100”, Smarty will always use that value for all
ECM updates. That’s, until you change the value again or return Smarty back to stock.
stacked and dyno'd
i have a 2006 ram with 5" exhaust, s&b cold air intake, ats air intake manifold, predator IV module stacked with PPE excelerator. i set it on level 3 of 4 on my PPE and pulled 410 hp and 778 tq. i believe 450 hp was possible (PPE on level IV). would be interesting what you would get with smarty jr, and mp-8. let us know! Dyno run in Milford, N. H. second week in june. :cool:
