Sometimes when driving, usually at low RPM and Low to mid speed, it seems like someone just shut off the key for a second... then it comes right back... it only lasts for a second or 2...
I have the Electronic "High Idler" that stacks on the TPS. . the switch for that is off when this code occurs... . I was going to take the connectors apart and clean them. . maybe that will help and then clear the codes by removing the battery wires for 30 min... If it does it again, I should have only 1 code plus the 1693.
The 0500 code is an old one I think... when I was hooking up a superlift Spedo calibrator.
Thanks for the info on timbo. If I need him I will E-Mail him
