gov spring install made a lot easier!
when you go to put the 366 spring in the whole assembly is made much easier if you remove the throttle lever from the pump top
you may then assemble the top hat, gov spring, and slide the throttle lever back into the pump top as the top is lowered on to the pump
the second set of hands pastor bob mentioned is no longer req if you assemble the pump this way
don
don
