eliminating post heat cycle
I did the fix the other day. Went to NAPA and the parts guy cross referenced the number (can't remember right now) but the fix works great. I think this is an excellent idea, the grid heaters now only do a pre-heat cycle. No more dimming lights and voltmeter dropOo.
Thanks for the great ideas!
Phil
Originally posted by WeirCummin
I did come up with a simple fix for the GH It will only let them cycle when the engine is not running=no oil pressure
Here is what I did to stop the cycling of the GH.
Get yourself a Borg Warner S320 oil pressure switch, it is N. C. (normally closed, open on rise) or equivalent. There is a port on the oil cooler/filter assy, 1/8" NPT.
For the wiring, it is only the control ground circuit that you are breaking so 16 to 20 gauge wire will work. From the switch you'll want to run a wire to both of the ground terminals on the GH solenoid coils. They are the two that are towards the firewall on each solenoid. The wire can be run in series since the factory wiring is done the same way.
Dean [/B]
Phil
