Grid heater in warm weather
Transfer case issues on 18 2500?
Aluminum dually wheels
2017 2500, now that the weather is warm, the grid heater "wait to start" comes on every morning on a cold start, even if it's 80 degrees. Dealer says it's out of the basic warranty, and it's not included in the powertrain warranty, so If it's just a sensor or something simple, I will fix that myself. Any ideas what to look for ?
What is the coolant temp when this happens?
The grid heater is used for emissions so it may well be normal. A failed sensor should set a CEL a the ECM will verify readings between multiple sensors on a cold start.
How long does it stay on for? Mine in a 2012 and still does it every morning as well. I never really think anything of it cause it doesn't seem to be effecting anything.
The light coming on for 2-3 seconds is normal. Just the system determining if it needs run the heater for a longer period.
I thought you could double pump the start switch to make the truck start up right away? ( the grids would probably be on anyways)
