Ok here is my problem I'm having. I have a 2000 Freightliner FL60 w/ the 5. 9 engine. I have to go through a sequence of things to start the engine. I finally tired of all that and decided to check the intake heater. What I found out was that it wasn't heating up
We checked the two relays that hand down from the cowling (?) and found out that the two big wires were bringing voltage to the relays but not voltate was leaving them. The relay has two small wires at the bottom and one large one coming from I guess the batterys. Would you suggest changing out the relays or hooking up some kind of wire that would be controlled in the truck? I checked the archives and might have discovered one little bit of info. I read where the intake cycles and that could cause the lift pump to not put out the same amount of pressure that it will after about 12-15 minutes of run time. I always wondered why it would be so low and by that I don't mean too low it still has about 8# of pressure on WOT. So now that you know all my issues can someone tell me what controls the intake heater? I believe the ecm is in charge and that tells the relays to relay power to the intake. I use a block heater so can I get away with just hooking up some kind of spring loaded button that I could just hold down for 10 seconds and then start the truck? One thing I have noticed is that the wts light only stays on about 5-6 seconds. Is that trying to tell me something? Thanks for the advice and this truly is a great site! ben
