Originally posted by sewman
If my heater solenoids ever fail I think I'd try Ford starter solenoids,has anyone tried them yet?
Bob
I was thinking of using them today, but I likely won't use them. Reason? Those solenoids are usually designed for short-term use, not up to the 3. 5 minutes the heaters can stay on.
I've done some more investigation today. Stancor make a relay designed for continuous duty that will handle 200A (586-902 for 12V control or 586-903 for 15V control). These are designed for use in electric winch applications, among others.
They warn against using the 12V unit in an application where the charging system brings the voltage above that, such as in our trucks. However, since the heaters draw the voltage down, I believe the 12V model will be the best.
However, they *do* cost around $60 each from Newark, and I'd need two of them, unless I wanted to trust the service manual - which says the heaters only draw 95A each - and use only one. If 25 of us were to get together, we could get the price down to about $40. Also, the lead time is 42 days!
More pondering is required. Anyone else have any ideas?
Fest3er
