Grid Heaters.. To Be? or Not To Be?
Test drove 01 H.O. 6 speed
Note: Me thinkgst all 5/24 posts have vanished?
All-right, My first post of this got lost in the great crash of 2001.
I'll sum up my post.
1. When removing my intake plenum to drill and tap a pickup for my boost gauge, I saw that the grid heaters ate up about 25% of the allready tiny intake hole.
2. I got a bright idea about disconnecting and removing them. Only problems I saw were clearance problems. (I would need spacers to take the place of the absent grid heaters)
3. I reasoned.
Reason A: It is ALWAYS Very warm here in the summer, NEVER Below 75*F (overnight low)
Reason B: If I removed the heaters. .
1. There wouldn't be a chance for them to self-destruct
2. I would be getting more air to the engine, and that would mean lower EGT's.
Okay, Those are my points for removing the grid heaters.
Has anybody else ever done this?
Would it harm my engine to do this in the summer? ( *I* Woulnd not think so. . but. . Ya Know)
I would think taking of my grid heaters would be similar to taking off the Fan (aka Going Fanless), as in, If it gets hot and you are without a fan,, You overheat. If it gets cold without your heaters, You get excessivly cold intake air temps.
Ideas Anybody?
MerrickNJr
1998. 5 Dodge 3500, 2wd
5-Speed, Light Driftwood
STRAIGHT PIPED! :)
3. 55_LSD
A. R. E. Camper w/side pop up windows
Michelin LTX A/T 245/75/16's
Autometer Gaugeworks 3 Gauge A-Pillar Pod
Fuel Pressure (0-15Lbs)
Boost Pressure (0-35Lbs)
EGT Gauge (0-1600*F)
ATS Manifold too!!
My"REAL" Hobby
Over about 62 degrees F, the grid heaters don't cycle anyway. If it's always warm in your location, you're safe to remove them entirely.
I believe HVAC has permanantly removed his intake heater for airflow benefit reasons. Any comments HVAC?
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger, Autometer Ultralite EGT and Boost gauges in 2-gauge pillar w/tweeter, DD Stage II injectors, boost module, and boost elbow. Yee haw!
http://www.rints.com/hammond for photos!
yes Hvac gutted his heater using the body as a spacer , the airhorn will not clear the TPS i think without it , Cummins must have a different airhorn or a spacer to replace it . i thought about do the same , except milling a spacer from a piece of billet stock wouldn't be that hard , also going to look at the banks hi ram for this , nice thing about the hi ram allows you to get in both hands for tv cable adjustment , not that that is a weekly occurance .
I've had mine out for about 4 years now and acctually was the one who convinced Nowel to take his out I think. I've never had a problem getting started at any temp even below freezing. #ad
96 4x4, 3. 54 posi, 6. 5"lift, 35" bfg m/t's and 35x14. 5x16. 5 boggers,dual stabalizers, aluminium wheels, sport headlights,billet grill, K/N 0880, NOS, Performance Diesel LPG, BD Pulling/Competition fuel injection pump,370hp marine injectors, ported head, Hx40 w/ 16cm2, 4" exhaust w/ 2 chamber Flomaster, BD copetition auto transmission and torque converter, Kenwood sterio System, Westach 60lb boost/ egt guage with warning light,aluminium bed rail covers,chrome diff covers, 5 foot traction bars,
475hp and 1050lb of torque on #2
530hp and 1140 with bullydog lpg maxed(only 55hp)
590hp and 1200 with lpg and nos
all done in 5th gear with 35's.
have a great day.
Adam
Your fine down to about 20 above. Then one heater helps. I got my truck started with one (of the two grids working) heater at -2, barly. Really cranked and sputtered. I would think you would need ether below -5 (no heaters to go BOOM!).
I never wait to start until below 30 anyway. Truck starts fine. 12Valve that is.
jjw
ND
I e-mailed bomber on this. Cummins does make a bare block spacer. I bought one when I put on my Banks High Ram. Cummins calls it a "Connection Spacer" part# 3922484 cost me $26. 74, but we get a discount,still wont be over $30. 00; Hammer Down #ad
98. 5,4x4qc,sprt,lthr,24v,5sp,354,Banks Stinger Plus with High Ram manifold,BD High Pulse injectors,BFG 265's,DMI chome rear bumper, gooseneck hitch
