I have been trying to track down a grinding or rubbing sound that in my mind sounds driveline. Two different shops test drove it and told me it was in the transmission (NV 5600) so I bit the bullet, had the transmission pulled and it all checked out fine so they buttoned it up, put it back in and charged me 500 bucks. Still grinds. Shop guy told me today when I picked it up to bring it back on Monday to talk with the head honcho about the cost, etc. and see what they could do - think he felt a bit embarrassed to hand me back a truck with a big bill and no fix, we'll get that straightened out.
In the interim, thought I'd see if can come up with some other possiblities - My best description would be a rhythmic grind/rub/friction sound that is very audible and increases in speed/rhythm as I go up thru the gears then dies away or becomes less noticeable when I get up to speed in 3rd gear. I can't feel anything in 4th, 5th, and 6th. I can kind of feel it thru the shifter a little bit. For some reason it feels like it's in the front, or at least not the very rear if that makes sense. Thru the years I've had about every U-joint on the thing replaced, probably multiple times. It has a new custom front driveshaft with about 20-30K miles on it. The joints all "feel good" when I get under there and give the a look over. Transfer case seems to work fine and I don't notice any change when I ran it in 4-hi today briefly to see if it did anything. Anyone have any other thoughts on which link in the system to check next. . ?? It's obviously got a problem that's no doubt going to get worse until it fails but I'd rather not be out on the road somewhere pulling horse trailers/traveling/etc. Thanks for any ideas - I know these kinda problems are tough to figure out over the WWW, especially when you can't figure 'em out in real life!
