Tonight as I was coming home from work I could hear a groaning noise coming from the transmission area. So I played around a bit with the clutch, it only happens when I downshift and when I press the brakes while downshifting it gets even louder. I am confused on what it could be, I just replaced the clutch at 50,000 and now I have 70,000 on her now. I also change the fluid around 60,000 with rp, its done good with that in there, so i hope that its not the problem. I also checked with the dealer before putting it in so there should'nt be a problem with warranties. Any info would be most appreciated, thanks corey
