Thanks for the pic's. Wanted to see different styles, also wanted to save the use of the grab handle on the pillar. Any use over head or dash mount?
Do you guys with the steering column mounted gauges have any trouble seeing the Odometer and Gear selector displays? I am thinking of going that route with the SRT-10 mount and two on the column. Thanks. <!-- google_ad_section_end --><!-- google_ad_section_end --><!-- / message --><!-- sig -->
The mounting is not done on the overheads, but you kindof get the idea...
I chose this route, because I wanted to keep the grab handle as well. The three on the dash probably offer the easiest viewing, followed by the one on the a-pillar. The column mounted gauges are easy to see, but cause you to shift focus from the road, to a very close object. The overheads house things that change more slowly (diff temps, trans temp, etc).
Thanks Wayne. I may go the Westec also. How dependable is the Westec?
