Installed the new turbo housing and gauges this past weekend. Went with a 16cm2 based on Piers' recommendation for heavy towing. There is a difference, not huge, but it seems to put the powerband right where I'll use it most for towing. Right foot action that used to produce black smoke now makes gray haze. Maybe a bit more "whine" also.
The gauges are great. Went with Isspro R3607T pyro and 40 PSI boost on a pillar mount. Drilled and tapped for pyro sensor while I had the turbo off so I didn't have any worries about metal chips going where they shouldn't. It's good to see where my EGT's are now instead of wondering.
Full throttle in 5th with my son's quad and my dirt bike in the bed showed 22 PSI and about 1000* EGT.
I am curious what temps I'll see when towing the big trailer up hills.
Might be hauling a car to OH this weekend, so I'll get an idea then.
The next thing is to bump timing and rpm. The trick is getting to the nuts to adjust timing. What tools/methods have you guys used to get to the one or two that are hidden? Piers suggested buying a cheap 13mm wrench and bending it into a U.
Thanks for any ideas! John
