Details here: TDR Privileges
The 44xx 4 wheel assist is 12K without 65 gallons of fuel, the other one could be around 5500, the trailer is 6-6500 and your truck is easily 7200 without the extra fuel. I'll say 31,500 and hope you have a CDL. The fat one on the back of the trailer smartly holds your pin weight down, but doesn't that trailer only come with 10K axles?
First the Trailer is 24k rated and the tractors are a 6410 and a 630 gas and a CDL is required for this load. Remember I made it thru 5 scales coming home legally. Keep in mind I also have a 98 gallon Transfer Flow.
If you came out of Maine did you come across I-90 thru NY? You passed by 2 miles from my house! Just off exit 34a east of Syracuse, jeez next time call ahead and stop for coffee!
my tractor is 18,500lbs and the baler is 17,261 with 2 bales and 100 gal of persevative. oh and dont for get the 16 balls of twine at 30lbs a pice. my truck goes 7400 and the trailer is 6900. not leagle but it works when moving from feild to feild
I'll try for 28,250. With a JD 70LP and an Oliver Hart-Parr 70 Row Crop on a 24 ft. double axle goose neck behind my '05 2500, my gross was 22,390. That is over the GCWR, but the truck handles it fine!
