Has anyone else noticed a gurgling sound coming into the cab just over 2000 rpm? I swear it wasn't there until my wife went up through the gears and grabbed 4th instead of 6th
There's no noticeable sound from under the hood, but it's detectable in the cab. Methinks a possible clutch item? Maybe a throwout bearing? It sounds almost as if something it supposed to fit snugly on a shaft, and now it vibrates above 2K rpm. It's a low pitched sound the you'd swear was someone draining the cooling system with a shop-vac, or slurping it out with a straw.
The irony of course it that I am running dd2s and an EZ, yet the stock clutch dies from a bad shift, not from the hp!
JLH
JLH
