Gutless truck; what's best to boost HP's, reduce EGT's?
Newest Smarty Download
Smarty jr or Edge with attiude?
I just posted that the truck (04. 5) has thrown a code and that the truck is very gutless, especially towing the horse trailer.
After I have the code issue fixed, I'd like something to bump up the HP a bit and something to reduce the EGT's ~150-200˚. What's out there that would be the best way to accomplish that mission?
All suggestions welcome. Hills that I climb include the Grapevine in SoCal with the horse trailer around 14K lbs.
Thanks!
For your situtation I would look at the Edge Juice with Attitude. 5 power levels adjustable on the fly and a whole lot of gauges. You will probably want to add a trans temp and maybe a fuel pressure gauge though. Some people will say Smarty but then you are on your own for gauges and you can not adjust the power level on the fly.
bigger exhaust system help to lower egt's ,helps eliminate back pressure. the air intake system starting from bigger air filter to turbo and then bigger and more efficient air cooler (which should make a noticeable difference up the grades)and then a bigger air ram. that all should help with cooler more dense air,lowering the egt's,better mileage,less restricted motor,more power and torque. if boost is up to 30-'s is what you may need for the torque to tow.
Mike S.
'04 dodge dually Banks six gun Power PDA with speed loader,AFE air intake filter system, Banks Techni-cooler system,Banks high-ram intake manifold, And Banks big head wastegate. Lots of power, better fuel mileage, and monitor the different temps ect. PDA also checks for codes and can clear them too.
I thank TCLUFF is on the money!! This will save you money in the longe run. All of the extra you add will cost more than you will ever get back!!It will not make it worth any more on trade in maybe less!!!
