I installed my . 45 skyjacker lift. Still running stock pitman arm. I obviously need a dropped pitman arm. What are you guys running? I called superlift and skyjacker and their normal 2-3 dropped arms are stock pitman arms with the taper backwards so the drag link is on the bottom instead of the top. The arm is the same length as stock...
any recomendations? How is your steering after your pitman arm?
