H2E driving impressions
Anyone tried MAGVIEW Cover?
Update Needed on 2001 Towing Mirrors.
After installing the new turbo, and now intercooler, I have to say Holy Horse Hockey Batman, this thing runs like Batgirl looks #ad
I'm building 55# of boost and the thing will set you back in the seat all the way to 4000 RPM. Bottom end kinda sucks though, power doesn't really come on until 2500rpm. Piers is sending me one of his custom HX35s, which I'm going to mount in front of the H2E, I believe this should remedy the lower rpm boost problem.
Don
96 2500 4x4 5spd 3. 54 grs, #10 TST plate(plate and housing slid all the way forward), AFC spring kit(light spring), Holset H2E-17cm turbo, CUSTOM 4" exhaust With 5" stacks, Custom air induction system With NAPA 2948 cylindrical filter, Banks Twin Ram intake manifold, ATS three piece exhaust manifold, TST guages, 370HP injectors, 3800 rpm governor spring kit, BD's High Flow delivery valves, "Accidently" modified fueling curve, Slightly advanced timing(17. 5deg. ) Modified valve lash, 60# valve springs,Powershot 2000 propane injection system, Mcleod dual disc clutch(street), Lockright lockers front and rear, Rancho traction bars, 315-75R16 Durango AT's on American Eagle 16x8 wheels for street use, 33-12. 50-16. 5 Denman Groundhawgs on 16. 5x9. 75 American Eagle wheels for pulling, Linex liner and rocker panels,
55lbs is about what I run too...
in my tires. #ad
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's, A pillar Boost/EGT,4" turboback exhaust,custom built aluminum airbox W/K&N-RE0860 through the cowl, and more to come...
Big_DQ,
So what are your egt's like,also how's the timming working out with the propane. I'm getting ready to set mine and I'm wondering if your getting any detination. You say you have it set at 17. 5 degrees, but how many mm's is that? The mech I've got to do mine said he had to convert it to mm's for what ever degree setting I wanted. I just do not know, so if I go into this knowning what setting I need I'll feel a lot better about somebody else working on my truck.
Sure sounds like your rig is running strong.
Let me know how the two turbos work out.
Brian Cobb
97 2500 CC 4x4 5 speed,egt & boost gauges, #5 tst,370hp injectors,4" exhaust,16cm turbo,Governor spring kit
afc kit,Pro Shot 2000,Psychotty Air, ceramic brass clutch,prozap, High flow delivery valves
Brian. I don't know what the EGT's are, my gauge only goes to 1500deg:eek; The timing is doing great, I have it set at 6. 1mm. I also had to drill the orifice in the propane system to get enough propane to feed my fire breathing dragon
96 2500 4x4 5spd 3. 54 grs, #10 TST plate(plate and housing slid all the way forward), AFC spring kit(light spring), Holset H2E-17cm turbo, CUSTOM 4" exhaust With 5" stacks, Custom air induction system With twin K&N RE-0880 air filters, Banks Twin Ram intake manifold, ATS three piece exhaust manifold, TST guages, 370HP injectors, 3800 rpm governor spring kit, BD's High Flow delivery valves, "Accidently" modified fueling curve, Slightly advanced timing(17. 5deg. ) Modified valve lash, 60# valve springs,Powershot 2000 propane injection system, Mcleod dual disc clutch(street), Lockright lockers front and rear, Rancho traction bars, 315-75R16 Durango AT's on American Eagle 16x8 wheels for street use, 33-12. 50-16. 5 Denman Groundhawgs on 16. 5x9. 75 American Eagle wheels for pulling, Linex liner and rocker panels, soon to come, Piers' modified HX35-16cm and H2E-17cm dual turbo setup
Wheres the pictures? I wanna see this beast, it sound awesome!!!!!!!!! YIKES 55lbs LMAO Keep up the good work!
1999 3500 Flame Red Sport 5 speed, K&N, silencer ring MIA, Stickers removed, BIG CHROME CUMMINS POWER cab plate on the front fender, 4inch exhaust, 5 inch chrome tip, cowl inducton hood... stock for now, but more to come
You have a 215 hp pump, right? 6. 1 mm is about NINETEEN degrees #ad
Have you seen aluminum specks on your injector tips yet? Your engine has my sympathy. #ad
5. 52 mm = 16 degrees.
[This message has been edited by Joseph Donnelly (edited 04-19-2001). ]
Joe, I tried to set the lift at 5. 6mm, and the truck ran as if it were retarded. So I called Piers to see if I had screwed up trying to find TDC. I did not trust the pin, so I tightened #1 intake valve a little, then barred the motor until it touched. I marked that spot on the balancer. then I barred it the other way till it touched again. marked that spot, then measured between marks. exactly halfway between was True TDC, or so I thought. Piers confirmed this was right. He suggested advancing timing until I got detonation, then backing off a few degrees. which is what I did. I then measured the lift and read 6. 1mm. The truck seems to run good at that lift. I guess only time will tell if I have screwed it up.
Don
