Details here: TDR Privileges
Hi, I'm thinking of running an hx35/h2e twins combo for a towing/street set up aimed at 500hp level. I'm looking for quick spool up and decent egt's. Do you think this will work or do I need to take the jump up to an Ht3b. thanks, Sean
I think you can get them in a 70 something mm wheel. Stick a 21+ cm housing on it and it should be an ok set of twins. Fast spooling and all. Just won't be big on the high end.
Big on highend isn't too much of a concern. I only want to run a mach 4 or 5, I just want something I can still tow with, so this sounds like it might not be too bad a set up.
