I left work yesterday, went one mile to the front gate and pulled up to the stop sigh to turn left when the truck cutoff before I got stopped. I pulled the Smarty out and it showed no codes. Changed to the stock program and nothing different. Went back to SW 1, still no change.
The truck would turn over fine but never busted off. Fuel Pressure was 19 psi when the FASS was running. Drained the filter, cracked the low pressure side line and then one injector line. All three had fuel while trying to crank. A few times while it would prime back up the FASS was at 5 psi for a few seconds the 10 then back to normal. This was only after I cracked the fuel lines.
Unplugged the Edge Box, no go. After about an hour we tried pulling the truck back to the parking area to sit over night. I tried one last time and she busted right off like nothing was wrong. Still no codes.
It acted like an air purge as if I had just changed the injectors except with no sputter or spitting.
Any Ideas? I'm sure if it happened once it could happen again.
Thanks
Thanks
