I tried to post on the proper forum but only 40 looks at the post and no reply. So I am posting here. I have a 98. 5 That has the speedo,voltmeter and fuel guage working. The oil,temp and tach is not working . Things I have done changed all sensors related to gauges. Pulled a friends gauge cluster and pcm and still the same gauges are not working. Sounds like it could be something simple since half the gauges are working. Also,checked the ground on pcm ,ecm and continuity between the CCD buswires from pcm and ecm. Thanks Damon
