The 355 is the diesel
MMmmmm GX 255
Power
20-hp, V-Twin, air-cooled engine provides smooth, quiet power
Cast-iron cylinders and full-pressure lubrication for longer life
Efficient and economical overhead valve design
Standard oil filter extends oil change interval
Performance
Standard 48- or 54-inch convertible mower deck for proven performance; optional 44-inch Piranha mulching mower deck
Full-length welded steel frame and cast-iron front axle for strength, durability and long life
20-inch turning radius provides good maneuverability in sharp turns and when trimming around obstacles
Traction assist helps pull through slippery areas
Comfort
Twin Touch™ automatic transmission provides comfortable two-pedal foot control for effortless speed and direction changes
Power steering makes turning effortless
Comfortable, high-back sit-and-adjust seat features 7 inches of travel; springs adjust for operator weight allowing for fine tuning of suspension; folds forward for protection from elements
Rubber foot pads help insulate operator's feet from vibration
Convenience
Separate engine speed and choke controls make starting and warming up the engine easier in cold weather
Oil pressure light and battery charge light monitor for quick problem identification
Translucent fuel tank provides visibility of fuel levels; large fuel fill opening located on tractor fender for easy access helps prevent spillage
Easy-to-use foot-pedal lift system makes changing cutting height and lifting optional front blade, snow thrower and rotary tiller quick and easy
Rotary dial adjustment knob makes adjusting mower cut height quick and easy; 1/4-inch mower cut height increments
Headlights and hourmeter are standard equipment
Cup holder and tool tray provides storage
Designed for fast and easy attachment installation and removal
