I installed my FASS system the other day that I ordered through PDR. I am very pleased with the value recieved. The unit is large and heavy duty, quality throughout. Kit was well designed and fit like a glove on my short box. I added one 90 deg elbow on the return to clean up hose routing.
I'm not sure how the product improvements have progressed but I read many posts on this system and concerns about bracket strength, filter, increases in performance etc. - I can not talk on reliability yet but if it lasts for more than a few $150 carter lp replacements I'm sure I'll get my moneys worth.
Entire unit is impressive quality -
Brackets are beefy. -
Filter was CimTek 3 Micron -
Pump starts up for 2-3 seconds at key turn to 'prime' the system and then back off to release pressure at start then back up to 14-15 psi. I never saw my stock setup jump the needle to give a little pressure to the system like the ECU obviously intends prior to actually hitting starter.
I plumbed the FASS feed line to the empty fuel filter to make use of the heater and WIF sensor. Also ordered another Genos banjo bolt with bigger holes for what's left of the stock fuel line between stock filter and inj pump - I already had one with a tap at the bottom of filter for my FP sender.
I really like this system Oo. - I even like the way it sticks out under the bed - should've come out of the factory like this -
