I spent the last two nights in Taos, NM. This is the first time in 55K miles my truck has spent more then 6 hours shut down in those temps, at that altitude. Mid 20's, approx. 7500'.
Both mornings the truck didn't fire up on the first crank. It started on two or three cylinders, I do not have the cold weather idle enabled. Yesterday morning I fed it some throttle and all cylinders came on line and it idled and ran fine. This morning, while trying the same trick (which did not work this time), I noticed I had no fuel pressure. I think the cam sensor wasn't seeing enough RPM to turn the pump on. I shut the truck off, bumped the starter twice to build pressure and it started up like it always does.
I'm using an anti-gel additive, and it starts and runs great all the rest of the time.
My first thought is a check valve in the fuel system, like the 12 valvers have. I've never heard of one on the 24 valve fuel system going bad. I'm in Albuquerque now, leaving for home on Sat. I hope it's nothing serious, but I don't want to get stuck if the problem gets worse.
Any thoughts or suggestions? Thanks, Jeff
