I've had no grid heaters for 15 months. The truck has been to the dealer three separate times. Each time I was told both grid heaters are cycling properly, the relays are fine, no codes were set, and I'm essentially full of crap. Still, the symptoms remained -- it was hard to start in 35 degree temps, there were huge clouds of white smoke on each attempt, the ammeter wouldn't drop when the "wait to start" light came on, nor would the headlights dim.
I've read all related posts on the forum, and posted one of my own. I've followed the suggestions (those I understood), including replacement of the AIT sensor. No dice.
Yesterday, I grabbed the thick 3" wire in front of the grid heater, and moved it. Dust crumbled from the upper end. I moved it a little more, and it broke off. I'm guessing it's a ground wire. The lower end is attached to a terminal, and the upper end is attached to a bolt. Anyway, I stripped the insulation, cut off the corroded end, reattached it, and guess what -- the grid heaters work great.
As you can tell by the simplicity of this fix, I'm an idiot when it comes to mechanical and electrical gadgetry. But, what does that make my dealer?
