Took the truck over to the dealer today and described to the service honco that my 6 spd was getting harder to get into reverse and 1st gear. But could be put into these gears with with two fingers if the engine is off. Second is getting a little harder also. If I let out the clutch at a light in neutral and then put it in gear it is a little harder that it used to be to slip it in rapidly. The wrench at the dealer said that it was definatily the clutch. I talked with Peter at South Bend Clutch and he said he was sure it was the syncro in the transmission and the clutch was fine!
Any body else out there with experiance along these lines ?
It has 70000 mi. and the clutch is pretty much been babied. The trany is running Red Line oil, 30000 mi. ago. All the other gears are fine going down the road. I side with the syncro's going south !! :{
