truck in sig. have redline in. had new ofe installed 6weeks ago. just replaced hydrolics for the clutch. when i come to a stop i shift to nuetral and sit. when its time to go i try to shift into 1st or 2nd and its very hard to get into gear lately. reverse is the same with the occational grind if i rush things. since everything clutchwise is new, i am wondering if the transmission is just too worn. should i look into a rebuild? would adding an extra quart of oil help or should i worry about leaking through seals or other adverse effects. any and all suggestions greatly appriciated. thanks
