My truck continues to have extreme hard-start problems in cool temperatures, even at temperatures as high as 30 to 35 degrees, and even after cycling the grid heater 2 to 3 times. Each attempt ends up in a huge cloud of white smoke.
I've had it to the dealer several times in the past year and a half -- each time I'm told the grid heater is working fine. When I turn the key to cycle it, I do hear a "click" when the "wait to start" light goes out, so I assume that means it is working. However, before this problem started, I could see my lights dim and amps drop when the grid heater cycled as I drove away from a cold start -- IT DOES NOT DO THIS ANYMORE!!! It certainly seems to act as though the grid heater is not doing its job!
Prior to October 2002, it started perfectly in temperatures as cold as the teens. That's when I had TSB 18-019-01 performed for cold idle engine warming. I've since read that TSB is only approved for automatic transmissions. I have the 6 speed manual. Could this explain why I've not seen any of the "cold idle engine warming" features work? Could this also be the cause of the hard-start conditions that have occurred ever since?
Should I have the cold idle engine warming TSB "reversed"? It isn't working anyway...
Is there some other troubleshooting I can try? I've already checked grid heater relays, and connections are fine. Anything else before I resort to going back to the dealer?
