I did a little research in the forums this morning and I am trying to make heads or tails of this hard start problem that I am experiencing.
A couple of weeks back we experienced a 1689 and replaced the VP based on information from my mechanic ( a reputable diesel shop). Having done that we left on vacation only to have it throw the same code during the trip. Truck ran fine but every once in a while would hard start, more so when it was warm but not always. Called my mechanic from the road he said drive it and when you get back bring it in.
We returned home just fine (it didn't leave us stranded) but still had the intermitent hard start.
The shop went through all of the wiring harness (checking communication) between VP and ECM all looks fine. Sent VP back to manufacture as they said it was a defective pump. New replacement installed and still have the hard start problem, no codes.
We installed the FASS95 just over a year ago and have never had a problem with starting, fuel pressure is a constant 17psi, 14-15 WOT.
I am baffled. I know that there have been issue with weak diaphrams on the VP and the addition of the FASS but that problem should have been present almost right after install prompting the mod for the delayed pump start that is in there (FASS) instructions.
Someone said that Smarty had a line of code in there programmer that is left behind that delays the LP on start up. Is this a possible fix?
Truck down two weeks now. HELP! Shop is doing everything they can and doing it under warranty. Just confused.
