Engine/Transmission (1994 - 1998) Hard starting 12V
Engine/Transmission (1994 - 1998) 3000 rpms effects?
Engine/Transmission (1994 - 1998) 370 opinions
I have a 98 12V that I'm having trouble with, I'm sure someone can help.
One morning truck would not start, it would fire but it was like it had lost prime. That night changed fuel filter, worked great, two days latter my wife says it died on her on the way to work!
Checked all connections no seeping or leakage. Truck is very hard to start, and would stay running below 1000rpm. replaced return fitting that seemed to help for about an hour. Now it will idle for about a minute and then it runs rough then dies like its running out of fuel.
Is my lift pump bad? Any help would be great!
Also ck. the fuel shut off solenoid for full retraction (pulled up). If this is a problem the solenoid could be bad, the solenoid relay could be bad or dirty batt. cables etc.
I don't think this is your prob. , but these will often act up intermittantly before being more easily diagnosed.
Good luck,
Andy
